Home page changed
for some reason my home page (the first screen you see when opening Plex) changed. previously, the home page would show my libraries and now it shows the ootb plex libraries. how do i get it back to showing my libraries? at the moment, i have to go to the more button on the left and scroll down to access my libraries.
If this happened in a web browser, then it might have to do with the browser’s preferences or the use of an app which aims to delete usage traces.
If you can, tell your web browser NOT to delete the cookies of plex.tv.
You can perform the ‘Reset customization’ procedure on the affected plex client(s):
https://support.plex.tv/articles/customizing-the-mobile-apps-2/#reset
https://support.plex.tv/articles/customizing-the-apps/#reset
https://support.plex.tv/articles/customizing-plex-web/#resethome
This will lead to a prompt to select your favorite media sources.
Or just perform the pin/unpin manually, as described in the above links.
