Server Version#: 1.20.4.3517
Player Version#: 4.43.4
As shown in my attached screenshot, I am no longer seeing the option for Automatic Sign In in the General Settings for Plex Web as indicated in the Plex Web Settings support article at https://support.plex.tv/articles/200289408-plex-web-app-settings/.
Does anyone know if this functionality been removed from the plex-web client? I looked through the release notes at Plex Web - #337 by chrishoage, but did not see anything suggesting this capability has been removed.
I only have one Plex user so I have NOT created a Plex home.
Given this last point from chris’s and otto’s helpful explanations in their replies above, it looks like I am stuck with having to login to Plex web each time I launch Safari. I know this was not the case in the past and I am sure there must be a good reason for this, but I have to say it does feel a little like a regression. Perhaps one day I will be pleasantly surprised and find it reinstated.
Thanks to all who helped me realize I wasn’t going crazy in not seeing it anymore.
That is an entirely different matter.
The automatic logon is for remembering the last-used member of your Plex home. Since you don’t have a Plex Home, it doesn’t apply here.
You might want to tell your web browser to not delete “cookies and website data” of the domain plex.tv when you close it.
Thanks for the suggestion Otto. I already have the Safari config set up such that it does not delete any Plex related cookies and website data but I still have to login each time I fire up Safari and go to my local Plex server URL (192.168.1.xxx:32400).
I don’t believe this ever existed. If it did, it was a bug. The purpose of the setting is to skip the “Choose Home User” screen when a home is enabled. It does have have any effect on the browser restoring your session.
This sounds like a bug, as that is not intended behavior.
I will take your advice on the option’s previous availability being a bug at the time etc, (even though it did indeed do exactly what it said on the tin … i.e. facilitate the automatic login following quitting Plex Web).
Either way that leads to your follow up questions to help diagnose if there is a current bug on restoring the login using cookies etc, without the settings option. So I just did some testing and …
Yes the issue occurs when I use the URL app.plex.tv instead of my servers LAN IP address and port 32400.
I installed Chrome and NO the issue does not occur when using either the server IP address or the app.plex.tv URL
The only Safari plugin I have installed is the 1Password extension.
I have been able to replicate this using Safari on 4 different Macs, including the Mac running PMS.
