I noticed a setting in the database:
PlexDatabase=>accounts=>auto_select_subtitle
I saw that:
- My master account is set to 2
- All the sub-accounts are set to 1
Correspondingly:
- When using the master account, subtitles start automatically
- When using the sub-accounts, sub-titles need to be started manually
Is there any way, other than editing the database outside of Plex to enable the same auto-start functionality with the sub-accounts?
There appears to be 2 ways to edit subtitle settings:
Upper right hand drop down box->Account->Audio & Subtitle Settings->Auto-select subtitle mode->Always enabled
I believe this is where the main account is getting set = 2.
=> This appears to actually work.
Settings->Server->Languages->Subtitle mode->Always enabled
This appears to be where the sub-accounts are getting set = 1.
=> This doesn’t seem to do anything.
Both appear to be controlling the same thing:
- “Auto-select subtitle mode->Always enabled”
- vs. “Subtitle mode->Always enabled”
Why are there two different ways of setting this and why does the only way that works only allow you to change the master account?
You need to use method 1) for your sub-accounts as well.
Use ‘Switch User’ first to become your managed user. Then perform method 1)
This way every user can have his/her own individual language preferences.
This only works for managed users though. If you share with regular plex.tv accounts as well (Plex Friends) they must perform method 1) themselves.
I’m not sure how I missed that. I thought I had tried that, but you are right, I switched accounts and there’s the option as well.
Out of curiosity, what does “2) Settings->Server->Languages->Subtitle mode->Always enabled” control?
I’m actually not sure. It used to be mirrored to the language settings for the server admin.
They really should consider removing the duplicate/non-functioning settings as it is very confusing. I’ve been mad at Plex for the last half-year because their subtitle functionality wasn’t working when I was just turning the wrong knob the whole time.
It’s like elevators that have a close door button which completely ignore when you push it.
I was told that the setting under
Settings - Server - Languages is only effective when the server itself is not signed into a plex account - which only applies to a very small portion of the Plex user base.
I have filed a request for enhancement to either get this setting removed as long as the server is signed in or to at least add a clarification for users and a link to the ‘right’ settings page.
