AutoPlay fails when AppleTV uses HomePods
I have an AppleTV 4k I recently added a stero pair of HomePods to - and now, autoplay doesn’t progress from one episode to the next - it just freezes on the new episode.
When I change the AppleTV back to using the built in TV speakers, it works just fine, and as expected. Also works fine on other players.
Sny ideas?
Try and get on the Apple TV beta.
Or failing that then go in to the Plex settings on Apple TV and try switching to the Old audio player.
Thank you - switcing to the old audio engine seems to have worked. I don’t know how to get on the Beta to test that, though
You can try this form for the beta I think.
