Autostart next episode
Hi all,
If I play episodes from the home screen (“on deck”) on Android it doesn’t autoplay the next one.
If I start it from the list episodes it does.
Anyway to also get it to autoplay after starting from on deck?
If you are playing from OnDeck, it should create a play queue with all the unwatched episodes and auto-advance to the next one. Make sure you are clicking on the 3 dots on the episode, then hitting play. If you go to the preplay page, it will only play that 1 episode.
Thanks, that makes sense.
I would have never guessed it, though
