Hello,
I already postet this Thread a week ago in The “PMS/Windows” Subforum but didnt get an answer. Maybe I find someone here to help me?
In the last 2 years I encountered a problem with the built-in Update function of Plex Media Server [Windows 10] that I just lived with until today. After clicking “Download” [PMS: Settings > Server > General], PMS is downloading the file and giving me the option of Installing after it has reached 100%, as it is supposed to do, I think [because it had never worked]. So far so good. But when i click on “Install”, after about half a second it says: “something went wrong, please install manually”. That is exactly what i have been doing for the last 2 years now. (Installing it manually then). I have tried multiple sulotions offered here in this forum, but I couldnt resolve it so far.
Beside that Update error, Plex is working Great! <3 o:) <3
What i think is the cause of the Problem:
I moved the Plex Folder and Appdata to another Drive [C: to D:]. But left the Plextemp on C:
D:\Plex\Plex Media Server= LocalAppDAtaD:\Plex\Plex Media Server.exe= Directory of ProgramC:\Plextemp= Transcoder Temp Directory
What i have done:
- On drive
D:check the chmod of the files&folders. Check the owner rights of the Folders according to Manfred73 - Using the Microsoft Fix It tool Plex Support Article
- Manual Installation. (Several times so far. Never solved the Update Problem)
- Check the registry according to sa2000
- Change back to
C:\Users\Server\AppData\Localby using a SymbolicLink pointing fromC:\Users\Server\AppData\Local\Plex Media Server\toD:\Plex\Plex Media Server\(and doublechecked in registry ifLocalAppDataPathis correct)
What I couldn’t do so far
- I found this article for a mac, but it is for a mac. The description of the Problem is similar to my problem. I only found the Butler Update Service in the registry but don’t know what what options i have to change it/disable it. Can’t update, “check for updates” is greyed out?
Plex Update Service Launcher.log
! May 08, 2018 09:28:05.048 [1484] DEBUG - “Plex Update Service Launcher.exe” “C:\Users\Server\AppData\Local\Plex Media Server\Updates\1.13.0.5023-31d3c0c65\packages\Plex-Media-Server-1.13.0.5023-31d3c0c65.exe” C:\Users\Server\AppData\Local\ “D:\Plex\Plex Media Server.exe”
Plex Media Server.log
! May 08, 2018 09:30:41.804 [1924] DEBUG - Jobs: Starting child process with pid 9044
! May 08, 2018 09:30:41.804 [8844] DEBUG - AutoUpdate: requesting check endpoint: /updater/products/1/check.xml?build=windows-i386&channel=8&distribution=english&version=1.13.0.5003-8fcb5b6e5, download: NO
! May 08, 2018 09:30:41.804 [8844] DEBUG - Downloading documenthttps://plex.tv/updater/products/1/check.xml?build=windows-i386&channel=8&distribution=english&version=1.13.0.5003-8fcb5b6e5
! May 08, 2018 09:30:41.805 [8844] DEBUG - HTTP requesting GEThttps://plex.tv/updater/products/1/check.xml?build=windows-i386&channel=8&distribution=english&version=1.13.0.5003-8fcb5b6e5
! May 08, 2018 09:30:41.849 [2764] VERBOSE - JobManager: child process with handle 0x1008 exited
! May 08, 2018 09:30:41.849 [2764] DEBUG - Jobs: ‘Plex Update Service Launcher.exe’ exit code for process 9044 is 30006 (failure)
! May 08, 2018 09:30:41.850 [1924] ERROR - AutoUpdater failed (30006)
! May 08, 2018 09:30:41.850 [1924] ERROR - Could not connect to the Update Service (30006)
Is there anything else I can do? I would really appreciate some help on my problem. I would love to update the PMS from my AppleTV and/or from the Built-In Update Function. ![]()
PMS Version: 1.13.0.5003
Thank you for taking your time to resolve my problem.
Best regards,
Christoph
