Hello,
I have read through the forums and added all of the ports suggested. AVG rep even remote access my PC. Still cannot use remote access unless I disable advanced firewall. Any suggestions? Thanks!
Hello,
yes, I have all reviewed that article and have all ports added to AVG. It is still not working unless I turn off the firewall. This all started after a PLEX update about a month ago.
Christopher J. Carbo LPC, NCC, CAADC, CCTP
Confidentiality Notice: This communication is intended only for the use of the individual or entity to which it is addressed and may contain information that is privileged, confidential and exempt from disclosure under applicable law. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you received this in error, please notify the sender and immediately delete the message. Thank you for your cooperation.
Not knowing AVG, but check if maybe it has kinda http inspection?
I’m not sure what that is. What should I be looking for?
Christopher J. Carbo MA, LPC, NCC, CAADC, CCTP
That AVG maybe scans for http trafic
The AVG forum has info on this.
Thanks for your reply. I had already found that thread on the Plex forum. All my settings are set to the criteria suggested. It is still not working unless I turn the firewall off.
Then I guess it’s time to switch FW, since it’s clearly defective
