Background transcoder operation filling up disk space
Server Version#: 1.19.4.2902
Plex is creating a huge (34+GB) runaway temporary file that is filling up my OS drive and crashing everything. I find the temporary file referenced in the log in reference to some background transcoding operations, sample below. These are part of some automated operation and not a file anyone is trying to view.
Jun 07, 2020 05:14:54.276 [5776] ERROR - [Transcoder] av_interleaved_write_frame(): No space left on device
Jun 07, 2020 05:14:54.286 [5776] ERROR - [Transcoder] [wav @ 030f1700] Filesize 34906321102 invalid for wav, output file will be broken
Jun 07, 2020 05:14:54.286 [5776] ERROR - [Transcoder] Error writing trailer of C:\Users\ADMINI~1\AppData\Local\Temp\2\d69456b1-51c0-4c5e-a6f6-1b79a388a498: No space left on device
Jun 07, 2020 05:14:54.887 [8412] ERROR - IntroDetector: Failed to transcode file to wav (1): M:\Media....mkv
There is a bug which causes the transcoder (while trying to identify tv episodes’ intros) to use the general system temp folder, instead of its explicitly designated location.
Settings - Server - Library - “Generate intro video markers”
Set this to “never” until the issue is fixed.
This should be the case in one of the next server beta releases.
Could you inspect the log a bit further, to try and determine which tv show and episode caused this outrageous file size?
