sign in in the Plex Web app (upper left in your screen shot above)
After signing in, you will get a message about an ‘unclaimed’ Plex server in your local network.
Claim it.
@faraz_hamza said:
thanks for your quick reply. but what i am asking i didnt found there.
The way I showed you above will lead to a ‘closed’ server which is not accessible without a login - IF you are using an up-to-date server version.
Which Plex Server version are you using? (Settings - Server - General)
i did install 1.2 in begining … but each guest viewer have to signup first. which is not my requirment. i dont want to force all guest users to sign in 1st… i remove that newer version and install older Version 0.9.16.6.
now i m using older version Version 0.9.16.6. in it no signin option is neccesory. but in it all guest user can create library. which should b ban
if a user do sign in. then they should have not the permission to create library or access to see drives while adding library.
is it possible all admin controls just be with admin user… all new created user will not have admin rights??
Yes, this is how it works in Plex:
You have a plex account faraz_hamza to which you only know the password.
Your server is ‘signed in’ to the same account.
Your guests need one or several plex accounts of their own.
You can create them for free here https://www.plex.tv/sign-up/ (each new account needs its own unique email address)
@faraz_hamza said:
is it possible to remove signup optoin from login page?
No.
i wan to user just use given login and password. nobody can create new account
A new account cannot be created on the signup page.
And even if it could, a new account has no access to your server. Only plex accounts with which you actively shared your server, get access.
