I use Power Director to create home videos some of my videos when playing on the plex server will stop and wait for things to catch up then play some more and sometimes just abort
I think maybe the server is converting the videos and does not have sufficient power to do so. What format should I use so the video does not need to be converted. some MP4 files have the problem
Case closed.
If you are playing one of these movies in a client which cannot play the HEVC video codec, Plex server must transcode. And since HEVC videos require a shedload of processing power to get transcoded, your server is not able to do the is fast enough. The results is frequent “buffering”.
You should better use the H.264/AVC codec for your home videos.
What is the best way to delete the old file and replace it. Do I just delete from the folder or do I need to delete it from the library first and if so how do I do that
