Good Afternoon Guys -
I’ve been using Plex for years now and love it! My primary Plex server runs on Windows 10 x64 and has about a dozen libraries which without getting too specific, contains ~ 26tb of assorted media. The only issue I have is that due to this, Plex’s Data folder contains no telling how many files / folders totalling almost 200gb! I understand why and how it works and do not have video thumbnails or anything fancy like that enabled, but do have the folder on a separate physical disk than other things. Seemingly, the majority of this data is Metadata .
All of my media is meticulously organized. Each title goes through 2 applications and sometimes scripts that clean it, fetch metadata, rename it, and sort it into a standard folder structure (details at end of post.) Due to this, it seems that the space and bandwidth Plex uses for its metadata per title is just duplications of what I have already. I know that there are options within settings per library to have Plex use local metadata instead of scraping each title and have even recently used the Media Center Master plugin (as it’s one of the scraping apps I use.)
My Question
Given how my media is organized, what would be the best way to configure Plex so that it uses minimal space in it’s data folder, but still performs as desired? I’m in the process now of reinstalling my Plex server from scratch and even though deleting the old Data folder via command line (del /f /s /q “Plex Media Server”) so it’s more efficient, it’s been running 30 minutes now and still hasn’t even gotten to the Metadata folders yet! Also - if I configure Plex to use MCM plugin or Local Metadata, does it read it from the source folder when needed - or - copy the locl metadata into the Plex Data folder. If the latter, then the option won’t be helping me much.
Below is how I have my media organized currently if it makes a difference for any potential answers. All of my media is on a 12 disk drive pool so all located on the same partition. Any suggestions would be appreciated.
Thanks!!!
Overall Folder Structure
- D:\Media
- D:\Media\Movies
- D:\Media\Movies-Collections\
- D:\Media\Movies-Collections\Name of Collection\
- D:\Media\Movies-Collections\Name of Collection\Movie Title [Year] Resolution\ (Example - D:\Media\Movies-Collections\Back to the Future Collection\Back to the Future [1989] 1080p)
- D:\Media\TV Shows\
- D:\Media\TV Shows\Show Title\
- D:\Media\TV Shows\Show Title\Season #\ (Example: D:\Media\TV Shows\Cheers\Season 1)
Files & Folders within Each Movie Folder
I typically scrape for Kodi which I frequently use and JRiver which I sometimes use
- .actors\
- extrafanart\
- extrathumbs\
- backdrop2.jog (Downloads all and sequentially numbers them)
- banner.jog
- movie.nfo
- movie.xml
- Movie Title [Year] Resolution.mkv
- Movie Title [Year] Resolution.nfo
- Movie Title [Year] Resolution.srt
- Movie Title [Year] Resolution.tbn
- Movie Title [Year] Resolution.mkv_JRSidecar.xml
- Movie Title [Year] Resolution-trailer.mp4
- Movie Title [Year] Resolution-trailer_mp4_JRSidecar.xml
Files & Folders within Each TV Show Folder
- extrafanart\
- Season 1\
- Season 2\
- Season 3\
- Specials\
- theme-music\
- banner.jog
- season01.tbn
- season01-poster.jpg (These 3 files per season / specials folder)
- series.xml
- theme.mp3
- tvshow.nfo
Files & Folders within Each TV Show Season Folder
- metadata\
- TV Show Title - S01E01 - Episode Title.info
- TV Show Title - S01E01 - Episode Title.mkv
- TV Show Title - S01E01 - Episode Title.nfo
- TV Show Title - S01E01 - Episode Title.srt
- TV Show Title - S01E01 - Episode Title_mkv_JRSidecar.xml
- TV Show Title - S01E01 - Episode Title-thumb.jpg (The last 6 files per episode in folder)
Thanks again!
