[BETA] Plexamp slowdown on cellular
Hey Elan,
Love the app & amazing updates.
I’ve had issues since before the flurry of updates, but can confirm on v4.50.21-beta.24, the app is noticeably slower on cellular than wifi. My main example is opening a playlist - instant on local wifi, but takes about ~35 seconds to load on data. Interestingly, the currently playing song will still play without that same delay. Plexamp is running on a Pixel 11 Pro, and Plex running on my own ubuntu/docker server.
Here are the logs, in the following workflow
  1. Open app on wifi
  2. Choose “shuffle” playlist
  3. Shuffle the playlist, playing the first shuffled song
  4. Force close app
  5. Turn off wifi
  6. Open App
  7. Choose “shuffle” playlist (~35 second delay)
  8. Shuffle the playlist, playing the first shuffled song
    Plexamp-Logs-2026-11-14-1.zip (164.7 KB)
Thank you for any guidance you may have!
Thanks, the logs had it. Off Wi-Fi your server’s direct addresses all time out and only the Plex relay works, but Plexamp waited for every direct address to fail before trying it, which is where the long wait came from. That’s fixed now, and separately, if port 32400 isn’t reachable from outside on your server, sorting that out would let cellular connect directly instead of via the relay.
Amazing work! The new beta cut it way down. The first time I tried it, it went to ~5 seconds, and sometimes it’s instantaneous.
Glad to hear!
