Biblioteca Plex
Hola, querría preguntar por un elemento de la biblioteca que incordia bastante. Cuando se borra una peli del disco duro porque momentánemente no la tendré disponibe aparece el logo de una papelera en la película. Hace tiempo conseguí que me apareciera solo el estado de No Disponible en la info del archivo pero no recuerdo como hice para que no apareciera el logo de la papelera encima de la portada. Como se hace?
https://support.plex.tv/articles/201447966-why-does-content-i-deleted-on-my-drive-still-show-up/
Eso significa que no se puede? ajajajajaja Es que el problema es que lo he conseguida varias veces pero no recuerdo como se hace. A lo mejor es que ya no se puede y francamente me parece un grave error estético porque para grandes colecciones es difícil mantenerlo todo en el disco.
Empty library trash.
https://support.plex.tv/articles/200289326-emptying-library-trash/
Sorry, if I misunderstood you. I only used Google translate.
Don’t worry. Actually, I want the trash symbol not to appear in the deleted movies.
Then Empty Library Trash. It will remove all items from your library which are no longer present on your hard drive(s).
If emptying trash doesn’t do anything, Edit your library,
go to the ‘Add Folders’ tab,
make sure that all paths listed in there are:
  • still in existence
  • Plex has access to them
  • the folder or drive is not completely empty
But I want to keep those movies in my library. The problem is I don’t want them to have that trash symbol on the cover. In this example this movie it’s not abailable but the cover is not covered by the symbol an that is what I want
You can’t do that.
Plex is not a librarian for offline-media.
There is a workaround, but it requires some labour:
Thank you very much
