I am testing the BGT3650 on a Windows 7 x64 (SP1) platform (Athlon X2 3GHz, 4GB RAM). The device is installed with BDA drivers v 9.1.0.5 and is working correctly in Windows Media Centre. Current Plex version is 1.8.4.4249.
Plex DVR setup detects it as 2 dual DVB-C (Cable) tuners, this card is actually DVB-C, DVB-T and DVB-T2 capable but as it is only detecting the DVB-C portion of the card it cannot tune into any OTA channels.
The logs show:
Sep 10, 2017 09:48:36.501 [8784] DEBUG - * BDA: get_tuner_type_from_filter. Unknown guid type {71985F4C-1CA1-11D3-9CC8-00C04F7971E0}
Sep 10, 2017 09:48:36.501 [8784] DEBUG - * BDA: get_tuner_type_from_filter: DVB-C/CQAM
Sep 10, 2017 09:48:36.502 [8784] INFO - * BDA get_tuner_type. Detected type(s) 2 for device @device:pnp:\?\pci#ven_1131&dev_7231&subsys_365014c7&rev_aa#6&26200fc1&0&00280010#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{353e20b5-4b13-4db0-b84e-1e0000040000}
Sep 10, 2017 09:48:36.507 [8784] DEBUG - * BDA: get_tuner_type_from_filter. Unknown guid type {71985F4C-1CA1-11D3-9CC8-00C04F7971E0}
Sep 10, 2017 09:48:36.507 [8784] DEBUG - * BDA: get_tuner_type_from_filter: DVB-C/CQAM
Sep 10, 2017 09:48:36.508 [8784] INFO - * BDA get_tuner_type. Detected type(s) 2 for device @device:pnp:\?\pci#ven_1131&dev_7231&subsys_365014c7&rev_aa#6&26200fc1&0&00280010#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{353e20b5-4b13-4db0-b84e-1e0000040001}
Sep 10, 2017 09:48:36.513 [8784] DEBUG - * BDA: get_tuner_type_from_filter. Unknown guid type {71985F4C-1CA1-11D3-9CC8-00C04F7971E0}
Sep 10, 2017 09:48:36.513 [8784] DEBUG - * BDA: get_tuner_type_from_filter: DVB-T/T2
Sep 10, 2017 09:48:36.513 [8784] DEBUG - * BDA: get_tuner_type_from_filter. Unknown guid type {C026869F-7129-4E71-8696-EC8F75299B77}
Sep 10, 2017 09:48:36.514 [8784] INFO - * BDA get_tuner_type. Detected type(s) 4 for device @device:pnp:\?\pci#ven_1131&dev_7231&subsys_365014c7&rev_aa#6&26200fc1&0&00280010#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{3ff44ee5-8547-402a-94f3-d40000020000}
Sep 10, 2017 09:48:36.536 [8784] DEBUG - * BDA: get_tuner_type_from_filter. Unknown guid type {71985F4C-1CA1-11D3-9CC8-00C04F7971E0}
Sep 10, 2017 09:48:36.536 [8784] DEBUG - * BDA: get_tuner_type_from_filter: DVB-T/T2
Sep 10, 2017 09:48:36.536 [8784] DEBUG - * BDA: get_tuner_type_from_filter. Unknown guid type {C026869F-7129-4E71-8696-EC8F75299B77}
Sep 10, 2017 09:48:36.537 [8784] INFO - * BDA get_tuner_type. Detected type(s) 4 for device @device:pnp:\?
THis seems to show that the card is being correctly identified as both a DVB-C and DVB-T/T2 tuner card however the only tuner source available to scan is Cable:-
Is there any way to force Plex to allow DVB-T/T2 to be selected.
