I’ve been on a mission to find a plex client that can achieve the following:
direct play of bluray rips
drive TV at movie frame rate (24 or 23.976hz)
wireless connection
I’ve finally gotten this to work thanks to lots of good information in these forums. this post is just a summary. Item (1) is to reduce load on my server and achieve the best possible quality. Item (2) is to reduce judder. Good TVs will detect 3:2 pulldown when driving them at 60hz and correct it, but many (including mine), cant reliably detect 3:2 pulldown (tested on rtings.com). Item (3) is because it’s difficult for me to run ethernet to my tv location.
Rasplex on the pi3 must be the cheapest device that can do all three of these things. I think the Nvidia shield could also work. Many other devices can not sustain the bluray bitrates, and even fewer devices will switch the TV to 24hz for 24p source.
This was mostly a technical challenge. Yes, I agree a bluray rip transcoded to 10mpbs and played at 60p on a roku is pretty good.
Steps needed:
Install 5ghz USB ac wifi. Bluray’s seem to average around 20mpbs, but I’ve read they can go as high as 54mbps. For me, with my router 1 room away, the built in pi3 2.4ghz radio could sustain ~40mbps to my server (as measured with the iperf app), but this was borderline and would result in occasional studdering/freezing during playback. With a 5ghz 802.11ac connection, I can sustain ~110 mbps which has resulted in flawless playback.
rasplex settings: make sure the “match refresh rate to source” is set. this can be checked by running “tvsevice -s” during playback.
I bought the VC-1 (and MPEG2) codec licenses. The VC-1 makes direct playback possible, otherwise the RPi3 can only decode a BluRay rip at about 3 FPS. The MPEG2 codec lowers the power requirement and the heat output. Total cost for both about £4.
Yes, I should have mentioned I also have the VC-1 and MPEG2 codecs, and use the MKV container for BluRay rips. It was never clear to me if these codecs are needed ( I thought the MPEG2 was for dvd’s?) but so far so good - about a dozen blurays I have have been able to use direct play.
Yes, they are worth it. I have about 600 films, a mix of about 75% HD-DVD/BluRay rips (all my own disks, which are now in the attic) and the rest DVDs. Then a similar volume of TV series, documentaries and foreign films, all a mix.
Without the MPEG2 codec I was getting the thunderbolt icon for low power and the thermometer icon for overheat when playing DVD rips. The VC-1 is an absolute requirement for about 1/2 the HD rips.
