BSOD with Plex
So, I’m not sure if this is a Plex specific issue or something else entirely. About 4 months ago I started running into BSOD issues. After quite a bit of troubleshooting I figured it was my RAM and ended up RMA’ing it. I just received it back about a month ago and I’m having the same issues. It seems isolated to whenever plex is running though. If I disable my server, I don’t have any issues, but once the server is up an running it’s anywhere between a couple of hours to a couple of days and I will inevitably blue screen. I tested this all last week by having plex disabled and had no issues whatsoever. Once I started it up again, within 4 hours I had a BSOD. I posted below the minidump from my last crash. Any advice would be appreciated because I’m pretty well stumped at this point.
Hardware Processor : 17-7820X 16 GB Trident Z RAM Nvidia GTX 1080 TI Mobo: Asus Prime X299-Deluxe Primary OS drive: Samsung 960 pro NVMe Storage Drive: WD MyBook 4TB
================================================== Dump File : 062318-23937-01.dmp Crash Time : 6/23/2018 4:54:30 PM Bug Check String : IRQL_NOT_LESS_OR_EQUAL Bug Check Code : 0x0000000a Parameter 1 : ffff9200b2a1c0c0 Parameter 2 : 0000000000000002 Parameter 3 : 0000000000000001 Parameter 4 : fffff8010ae9733b Caused By Driver : ntoskrnl.exe Caused By Address : ntoskrnl.exe+198330 File Description : NT Kernel & System Product Name : Microsoft® Windows® Operating System Company : Microsoft Corporation File Version : 10.0.17134.112 (WinBuild.160101.0800) Processor : x64 Crash Address : ntoskrnl.exe+198330 Stack Address 1 : Stack Address 2 : Stack Address 3 : Computer Name : Full Path : C:\WINDOWS\Minidump\062318-23937-01.dmp Processors Count : 16 Major Version : 15 Minor Version : 17134 Dump File Size : 2,299,954 Dump File Time : 6/23/2018 4:58:26 PM
does it crash whether you are paying content from plex or not?
You should (don’t have to) post this over at the official Microsoft Community boards.
https://answers.microsoft.com/en-us/windows
Best advise I can offer on this one.
Nope, whether content is streaming or not doesn’t seem to make a difference.
Will do, thanks!
That was the minidump file
It is best to raise windows crashes on windows forums - eg the microsoft one mentioned or even the https://www.tenforums.com which has a section specifically for BSOD - https://www.tenforums.com/bsod-crashes-debugging/
You’re welcome. :slightly_smiling_face:
