Buffering Playing 4k Movies
Good day,
I have a problem what formerly works fine and perfection! While playing 4 k movies MKV I get this message in image, server is not powerful enough to encode the file trans. The server is on my pc and the plex player on the Nvidia Shield.
I have this problem now for about a week. I think the last plex server update!
The plex server runs on Windows 10.
System.
Operating system
Windows 64-bit 10 Pro
Processor 33 ° c
6500 @ 3.20 GHz Intel Core i5
14nm Skylake Technology
RAM
16, 0 GB Single-Channel Unknown @ 1600 MHz (16-18-18-36)
Motherboard
Asustek COMPUTER Inc. MAXIMUS VIII HERO (LGA1151) 39 ° c
Graphic
S24C750 (1920 x 1080 @ 60 Hz)
2047MBNVIDIA GeForce GTX 750 Ti (ASUStek Computer Inc.)
The system should be powerful enough for stream 4 k movies have Always used this way and everything plays smoothly with subtitles and sound source DST-HD Master or Dolby True HD .Mkv file of 100 GB or 25 GB played smooth without any vibration.
As I now have a 4 k film playback is 100% CPU consumption. 1080 p movies still play flawlessly. CPU consumption is around 10%
It seems to me that it is an update of the plex server It would be good again should be able to work because formerly turned everything flawlessly.
Sorry for the bad englisch
Best regards,
Marsnldxx
Does anyone has the same problem?
