My plex server is a Ubuntu box with internal hard drives for media. Lately I’ve been getting a problem where plex buffers, usually just once, around a half hour into a movie. After it buffers this one time, it usually plays the rest of the way through no problem. I’ve attached the logs. It happened again at 08:17 am today (Sep 10). This log capture is from about one minute after it buffered so the event is close to the end.
I see two entries like this:
Sep 10, 2017 08:17:49.248 [0x7f0a673ff700] ERROR - Throttle: timed out trying to read chunk 1
Sep 10, 2017 08:17:49.564 [0x7f0a627ff700] ERROR - Throttle: timed out trying to read chunk 1
Do I maybe have a hard drive problem? I’ve not seen any other errors to make me think I could have a HD issue so I’m not really sure what to think.
Media details:
Media
Video Resolution 1080p
Duration 2:16:17
Bitrate 10641 kbps
Width 1920
Height 798
Aspect Ratio 2.35
Container MKV
Video Frame Rate 24p
Audio Profile dts
Video Profile high
Part
Duration 2:16:17
File The Matrix (1999).mkv
Size 10.13 GB
Audio Profile dts
Container MKV
Video Profile high
Codec H264
Bitrate 9135 kbps
Bit Depth 8
CABAC true
Chroma Subsampling 4:2:0
Duration 2:16:17
Frame Rate 23.976 fps
Frame Rate Mode cfr
Height 798
Level 4.1
Pixel Format yuv420p
Profile high
Ref Frames 5
Scan Type progressive
Width 1920
Codec DCA
Channels 5.1
Bitrate 1510 kbps
Language English
Audio Channel Layout 5.1(side)
Bit Depth 24
Bitrate Mode CBR
Duration 2:16:17
Profile dts
Sampling Rate 48000 Hz
Codec SRT
Language Nederlands
Format SRT
Server details:
8-core i7 4790 CPU @3.60GHz
8GB RAM
Ubuntu 16.04
Thanks in advance!
