On Deck, Recently Added, Continue Watching etc are now missing from the main dashboard for all libraries. At times clearing the cache works others times it does not.
logging.txt.zip (286.9 KB)
[7.9.0.8414-beta] Has the same issue.
Same issue with latest [7.9.0]
Thanks for the report. I can’t reproduce the issue on my SHIELD.
I will investigate your logs and get back to you.
@marekszulik, This is probably a duplicate post with my server one [1.14.1.5488] missing items from homescreen . There are additional logs in that post as well.
After removing the Cache directory from the server a third time, things have started to work again.
