[BUG] [Android TV player] "More Info" screen shows incorrect encode details when there are multiple versions
On the Android TV player, the “More Info” screen shows incorrect encode details when there are multiple versions.
The “File”, “Location”, and “Size” lines are correct. However, the lines for “Video” and “Audio” (all of them) for the second version simply duplicate the the details for the first version:
This occurs for all items which are duplicates (i.e. have multiple “versions”). Items with a single version do NOT have any errors.
The Web App shows the details correctly:
Given this, I’m assuming the server/database is fine, and the issue is the the android tv player.
“Play version” on the android tv player shows the correct details. Given this, I’m also guessing it’s a simple UX issue where the encode details are simply reading the “item” encode details, rather than the “version specific” details
I use a 2019 Shield Pro as server and player. Server Version#: 1.23.1.4571
@BigWheel Could I please get your assistance on this one?
I’ll let our android devs know
