[Bug] Certain Menus Can Be Triggered Twice
In certain cases the slide-in context menu on Plexamp can be queued multiple times resulting in the menu opening again once it’s been closed.
I was able to reproduce this issue on Plexamp 4.9.0 on both iOS and Android with server version 1.32.8.7639.
Example:
  1. Have a track actively playing
  2. On the home screen under the “History” section double tap a track entry. If you don’t already have a track playing, the first tap will simply cause the track to play and take you to the “Now Playing” screen; the second tap doesn’t generally hit anything meaningful in this case.
  3. The context menu should open up as a result of the first tap, the second tap should queue the menu to open up again after you dismiss the menu (either by tapping on the area above the menu, or by swiping down).
I’ve also been able to reproduce this issue with similar steps in the “Album” view, but it’s much less consistent and in some cases the second tap seems to cause the menu to automatically close after it opens without opening the menu a second time (though that may have been due to the second tap hitting the “Play” menu entry as the menu was sliding in).
I suspect that there’s other places in the app where this may occur but I haven’t had the chance to test all places this might happen.
I’ve confirmed that this issue still occurs on 4.9.1
