Bug in Plexamp 3.2.2 : My Playlists > 3 dots menu > Title Sort not working
I’d like to report a bug in Plexamp 3.2.2. Go to My Playlists > 3 dots menu > Title Sort not working
Selecting the Title ^ or down carrot and nothing happens. No additional sorting occurs. The expected behavior would be to resort the Playlists names according to Title alphabetical. If you are going to fix this, then perhaps you can add sort by “last played”.
Thanks for fixing!
Best regards,
Michael
This is working in 3.3.0 beta, out soon ®
There is also sort by Last Played.
It was’t working in TIDAL, unless I’m smoking crack (web app doesn’t even show the sort option). @OttoKerner is talking about servers, I think.
I removed it from the My Playlists menu for now until it becomes something you can do.
I was talking about the playlists item in plexamp. Either Recent Playlists on the home page or Playlists on the Library tab.
I did not try this with Tidal selected as media source. It was not indicated anywhere in the first post.
Plex Media Library Playlists sorts as correctly expected when clicking 3 dots menu to sort.
Tidal does not. I checked on the Tidal web player and it does successfully sort by playlist title alphabetical and by date. I’ve attached a screenshot to show. Would you be able to fix that in Plexamp now that you know it works correctly in Tidal?
Thank you Otto! I didn’t see your post until after I posted the screenshot of Tidal sorting correctly.
sadly not, it’s something our cloud service would need to fix.
