[BUG] Latest iOS app completely bypasses PIN requirement for home users
Server Version#: 1.41.5.9522
Player Version#: 2025.12.0
Steps to replicate:
Add a home user, protect main profile with PIN.
Perform clean install of iOS app (specifically I tried on iPad).
The initial setup screen shows, presenting only the main profile and not requiring a PIN to access the data within that profile.
Only when explicitly changing profiles afterwards, the app will start asking a PIN for the PIN protected profile.
wtf Plex, really?
That’s completely normal and expected (as you’re already logging in with your main credentials).
Do you have “Automatically Sign In” enabled in the Settings → Account?
Automatic sign-in is disabled. It seems to request a PIN each time on any other platform. I guess indeed inviting external accounts as home users may fix the issue in this case. Still, weird that it’s not asking a PIN on initial setup.
Thanks I’ll ask somebody to double check what the behaviour should be.
