[BUG] Live TV with closing captions doesn't work on iOS
I tested the latest Plex for iOS update (4.14) on iPad which works perfect (could have been a program without subs). I then tried to do the same on iPhone (6). The pre-play screen hangs and gave an error to retry. I then clicked the retry button and the wait spinner ran without stopping. I checked the PMS logs and i could see a lot of these in Plex Media Server.log.
Jun 28, 2017 10:52:59.334 [0x7fb5dbd11700] WARN - ClientProfileExtra: ignoring directive: add-transcode-target(type=videoProfile&context=static&container=mp4&videoCodec=h264&audioCodec=aac,ac3&subtitleCodec=mov_text)
Jun 28, 2017 10:52:59.334 [0x7fb5dbd11700] WARN - TranscodeUniversalRequest: at least one profile extra directive could not be read
Jun 28, 2017 10:52:59.334 [0x7fb5dbd11700] ERROR - ClientProfileExtra: video transcode target already exists for streaming hls
After 2-3 mins PMS crashed. I haven’t been able to find the reason for the PMS crash in the logs. No crash report created.
This only happens if the program has subtitles. If i try the same on a local program without subtitles - it works.
PMS: 1.7.4.4017
Plex for iOS: 4.14
QNAP FW: 4.3.3.0229
PMS and Plex for iOS logs attached. Occurred at 10:50. PMS logs was copied before PMS restart.
When i restart PMS it won’t (re)start and PlexWeb in unavailable. The PMS logs are full of these:
Jun 28, 2017 11:09:12.599 [0x7fc50d047700] ERROR - [Transcoder] [h264 @ 0x2e48a00] SPS unavailable in decode_picture_timing
Jun 28, 2017 11:09:12.601 [0x7fc50d623700] ERROR - [Transcoder] [h264 @ 0x2e48a00] non-existing PPS 0 referenced
Jun 28, 2017 11:09:12.603 [0x7fc50d911700] ERROR - [Transcoder] [h264 @ 0x2e48a00] SPS unavailable in decode_picture_timing
Jun 28, 2017 11:09:12.604 [0x7fc50d047700] ERROR - [Transcoder] [h264 @ 0x2e48a00] non-existing PPS 0 referenced
Jun 28, 2017 11:09:12.606 [0x7fc50d623700] ERROR - [Transcoder] [h264 @ 0x2e48a00] decode_slice_header error
Jun 28, 2017 11:09:12.607 [0x7fc50d911700] ERROR - [Transcoder] [h264 @ 0x2e48a00] no frame!
Guess I have to reboot the server …
UPDATE: Reboot solved these errors and PMS is running again.
Tested on iPad. The same happens. This actually kills any active recordings on DVB Link Server (plex wasn’t recording anything).
Bump … anyone?
Need fresh logs (zip of whole logs folder as that would have crash report identifiers)
Your logs above are from June
Please reproduce with version 1.7.6.4058 and get the logs zips
PMS Logs attached. It is actually “flooding” my logs when the iOS app is waiting/hanging.
Sorry what is crashing ? no evidence of a Plex Media Server crash in the logs you attached.
I misunderstood - I think because of the title of the topic
Is the issue that you get continuous errors when viewing live tv on the iOS app?
Please edit the title of the thread to reflect that and please could you now also include the Plex for iOS logs
I will need matching set of logs - so if the iOS app logs do not go cover time in the PMS logs you just attached, please include a new set of matching logs. I am sorry for the misunderstanding - I was looking for a Plex Media Server crash
And please indicate what time was the “crash”
Is it a loop of repeated errors?
Title updated.
Like i wrote in the initial post there weren’t any crash reports or indications of a crash in the logs. PMS has been updated in the meantime.
The problem with closing captions still exists. I can play any Live TV without closing captions, but when i select ex. a german channel with closing captions (I’m from Denmark) the iOS app hangs and will now crash the iOS app (and not PMS anymore). Plex for iOS Logs attached - matching the previous PMS logs.
If you check the PMS Plex Media Server logs (the 5 files), they contain the same info over and over again for a very short period (time-frame)
Jul 14, 2017 17:51:34.731 [0x7f08ff66b700] ERROR - ClientProfileExtra: missing protocol parameter
Jul 14, 2017 17:51:34.731 [0x7f08ff66b700] WARN - ClientProfileExtra: ignoring directive: add-transcode-target(type=videoProfile&context=static&container=mp4&videoCodec=h264&audioCodec=aac,ac3&subtitleCodec=mov_text)
Jul 14, 2017 17:51:34.731 [0x7f08ff66b700] WARN - TranscodeUniversalRequest: at least one profile extra directive could not be read
Jul 14, 2017 17:51:34.731 [0x7f08ff66b700] ERROR - ClientProfileExtra: video transcode target already exists for streaming hls
@mm98 said:
Title updated.
Thank you - this has been referred to the development team
@mm98
Please could you confirm if this issue is still there - recent tests did not show the problem
This can be raised as a separate issue and I can split out the posts into a new topic
At this moment what I am after is if this issue is still there
Correct! Please split it and I’ll mark this as answered …
I have split the new problem and it is here
I can confirm that closing captions are working on some channels. Other channels that have ex. “Teletext” and “Teletext subtitle”, only show “Teletext” overlay on iOS.
Sat1 channel stream:
Sat1 on iOS:
I don’t know if this is intentional … I just report what I see :blush: Lots of European channels use teletext subs …
PMS “Languages” settings:
