Server Version#: 1.32.3.7192
Android Plex Version#: 9.28.0.3162
I previously had to report this bug for versions 8.7 [Oct 2020] through 9.9 [Sep 2022] because, hey, it should only take 23 months to fix a bug, right? On Android, you can specify two manual connections in advanced settings and Plex should attempt to connect to the server and it will become visible in the menu. 9.28 does not.
This bug has been reintroduced with version 9.28 on Android.
It would appear this feature worked through 9.27.0.2856, and was broken first in 9.28.0.3162.
This is still broken in version 9.29.0.3427.
This is still broken in version 9.30.0.3604.
This is still broken in version 9.31.0.3817.
Confirm this is an issue. Sadly
This is still broken in version 10.0.0.4149.
This is still broken in version 10.1.2.4386.
This is still broken in version 10.2.0.4488.
This is still broken in version 10.3.0.4685.
This is still broken in version 10.4.0.4843.
This is still broken in version 10.5.0.4996.
This is still broken in version 10.6.0.5141.
This is still broken in version 10.7.0.5386. It has now been 160 days since reporting this bug.
This is still broken in versions 10.8.0.5554, 10.9.0.5676, and 10.9.1.5708. It has now been 194 days since reporting this bug.
This is still broken through version 10.12.1.370. It has now been 243 days since reporting this bug.
This is still broken through version 10.14.0.541. It has now been 274 days since reporting this bug.
This is still broken through version 10.16.0.758. It has now been 300 days since reporting this bug.
This is still broken through version 10.19.1.1166. It has now been 363 days since reporting this bug.
This is still broken through version 10.22.0.1579. It has now been 424 days since reporting this bug.
