YoMo
November 8, 2021, 2:19pm
1
Server Version: 1.24.5.5173
Android App Version: 8.25.1.28703
Android Version: 12
Device: Google Pixel 6
It’s impossible to set manual connections through the app. The IP field does not allow editing and crashes the app when the feature toggle is enabled.
Android app version: 8.26.0.28833
Pixel 3a XL, Android 12
Same. Enabling the feature restarts the app. It stays enabled after the Plex app restarts, but still unable to enter a server IP address.
I am having the same problem, really need to set fixed IP address as I am on a boat and often away from internet coverage.
Did you ever find a solution?
Can you guys try again on the latest beta 8.26.0.29143? I’m not able to reproduce. A couple of fixes related to server connection tests were made recently.
The problem occurs with 8.26.0.29143. Plex is able to replicate. They’re investigating.
FYI, my phone updated to the latest beta. I can now go into Advanced settings and configure a manual connection.
Plex for Android 8.28.0.29906-beta
Available on Google Play , beta access can now be joined (or removed) directly from the Google Play store listing.
FIXES:
Player: prevent content getting stuck after advert playback.
Player: upgrade ExoPlayer to v2.16.1.
Downloads: improve download speed when downloading onto external storage.
[Mobile] Live TV: setting recording offsets would cause a crash on Android 12.
BETA:
[Mobile] Settings: crash could occur when opening advanced settings.
DOWNLOAD …
system
Closed
March 18, 2022, 1:50am
11
