Looks like from reading multiple threads on here that this has been an issue on Plex for a few years now. When recording a film that is split into 2 parts on the guide, usually by a short news update or channel update message, the second half of the program is not recorded. These interludes are in the guide and the guide shows up correctly as if it will be recording both halves.
I don’t believe this is a guide issue, which seems to have been explored in multiple threads. I would say it’s more likely to be the code not looking forward in the guide correctly. It clearly matches the movies ID in both halves but maybe it’s treating the second half as a duplicate or simply ignoring it when it comes to recording.
Logically, anything on the same channel with the same ID and within an hour of the first match ending should be classed as a continuation and hence the end time should be extended to use from the second parts data. This would record straight through including the interlude and then allowing the set Minutes after end to work as expected.
With this bug present I am having to check every movie and find that I’m deleting probably 30-50% of my movie recordings.
A temporary work around is to set the Minutes after end to 90 so it will be forced to record straight through (I use 90 for speed when setting up). This work around does also mean that it’s increasing my post processing time as I now have to convert additional footage to H264 (MP4) that I might not want.
Recording settings:
- Prefer HD
- Replace lower res items = false
- Allow partial airings = true (tried false as well both same for this)
- Minutes before start: 2 (Like a little buffer for start)
- Minutes after end = 2 (Like a little buffer after)
- Limit channels = Any
- Limit Airings = any
- Remove commercials = No (find it cuts to much out or still leaves random ones in)
- No conversions, I just have it save the raw ts file and post process on separate computer later on
- Guide reports correctly even showing the recording symbol on both parts when set (see image above).
Ran a check on 2 other DVR platforms and they just record straight through including the Interlude. Devices I used: Virgin Media (which I think is a Tivo box) and Humax Freesat unit. Both never have a problem with split programs.
Server Version#: 4.33.1 on a mac mini
Player Version#: Not relevant as file not correct
Tuner Make/Model: Quad HDHomerun connect
Guide/Lineup name: Freeview Yorkshire OTA Broadcast (UK)
Using XMLTV?: Not sure where you find this
Channel number/Name: Effects multiple channels that do these type of splits, seen on Five, ITV (all) commercial channels started doing this a lot in the UK.
