[BUG] Plex 4 Android 8.15.0
PMP 8.15.0.23855
Latest PMS
Nvidia Shield TV
Android TV
@marekszulik
Still has a BUG. There are multiple rows of the same On Deck Hub listed for each pinned item on the Home Screen despite what the side Library pins are.
Some On Deck Hubs are still disappearing/reappearing.
This is one of the correct On Deck Hubs
that should be showing on the Home Screen for this particular pinned library item.
Please fix this
Is this using Manually Managed Home, or Automatically Managed?
Manually, because the automatic home screen settings is cluttered.
You may not have seen, but manually managed home screens will be going away, as of April 22nd, so you will need to switch to the Automatically Managed Home Screen. As such, we’re not putting any more time into fixing issues with the manually managed Home Screen. However, you should be able to customise your Home Screen quite a lot with a combination of which libraries you pin and the features documented here: Manage Recommendations | Plex Support
I saw that, horrible plan. I have quite extensive libraries, so that type of customization would be cumbersome.
I ended up rolling it back to 8.14.0. and most likely will remain there. There’s still some randomly disappearing/reappearing on deck hubs, but it is better then repeating hubs…
Thanks for the assistance.
I’m guessing you also missed the announcement that the ability to merge Recently Added hubs is returning too?
Yeah, saw that.
