New server beta broke Android home hub
Running most recent plex pass on all.
Tonight’s server update broke Android home hub. They have totally disappeared. All that’s left is the plex on demand stuff. Looks fine via web and roku.
If you haven’t resolved this yet resetting customization (restoring defaults) for you home screen may help. See “Reset Customization” in this support article:
This should take you through the first-run configuration wizard for the app allowing you to pick your default server and select which libraries you’d like pinned; it will then automatically populate your home screen.
I had something similar happen with my web client after the server update; resetting customization corrected the problem, though of course I did have to re-customize things.
Done this 3 times. The pinning to side bar is fine but the hubs like on deck, newly added, etc… do not show up.
see also @
It’s broke. Nothing I’ve read has resolved the issue.
