That’s a different issue than this thread is about.
Please start a new thread
The App you are using is not a Plex App, but a 3rd. Party app provided by @Orca and is discontinued
It’s not a different issue exactly. My issue started because Samsung went through an update and deleted a few apps, including Plex. When I have tried reinstalling the app, I no longer have an ability to access the Plex library via the TV and app.
What are my options for a Plex TV app if the one you are referring to has been discontinued.
If your Plex App is present on your Sammy, then yes…Different issue!
This tread is about Plex App gone from the Sammy!
neues updat ist drauf akutelle Version 1.15.1.791 ist auf meine nas drauf lauft immer noch nicht ,ist was auf gefallen wen ich mein pc an mache mit plex lauft die tv app mt die beiden sever und wenn ich mein pc aus mache lauft meine tv app hat kein zugrifft auf meine nas plex nicht
Used Plex fine on a Samsung TV on the 07/04/19 then on the 08/04/19 I got a message when trying to start the app " This app has been terminated by Samsung", Its still in the Apps store but you get the same message when trying to install it again.
Has Samsung stopped allowing Plex for some reason now
This topic was automatically closed after 90 days. New replies are no longer allowed.
