Apologies for double posting this, but I now realize that this is the correct place to report bugs in the beta. It was previously posted at Plex menu in Android Auto is wrong.
Server Version#: 1.17.0.1709
Player Version#: 7.22.0.12686
The menu hierarchy in Android Auto is simply wrong. Basing my recommendations on the Plex app, It should be organized and behave as follows.
- Music Libraries - separate entry for TIDAL
- Downloaded - moved up from library specific level
- {each library is correctly enumerated here}
- Recently Played - not currently limited to selected library scope
- Playlists - not currently limited to selected library scope
- Recently Added - not currently limited to selected library scope
- Artists - not currently limited to selected library scope
- TIDAL - moved up from the “Music Libraries” level
- Podcasts
- {looks good from here}
It should be noted that the Plex android app presents Play Lists as if they are library specific. The Plex web shows Play Lists at a level above libraries. Not sure is Play Lists can actually cross/span libraries, but it they can, that would change the position of Play Lists in the above menu hierarchy. It would also suggest that the Plex app itself is presenting Play Lists incorrectly.
