I have been looking into this a bit and it is external only. If I connect to my device using the internal network (192.168.x.x:32400/web) then plex mix works. If I do it from plex.tv/web (while inside my house) it plays music ok but it does not play a mix.
I have a watchguard with really robust logging and I was thinking it was a firewall issue but it’s not giving anything on the device. All the data is passing cleanly through. Something in an update or on the website is not working properly if that helps.
@FastKatt said:
Does not work with a secure connection.
Just on a whim, I tried this with an insecure connection outside of the network and got no different results. Can confirm the issue with plex.tv/web instead of localIP/web.
Adding in my findings to keep track of the issue as well. Glad to see Plex has picked it up.
Please could you look at settings / web / general and note down the version number for Plex Web for each
Non-working web external: Version 2.9.0 in either Chrome or Firefox.
Working web local: Version 2.7.10 in either Chrome of Firefox
Also, I have tested that the Plex Mix feature works fine in both the WIndows 10 mobile phone app and the Windows 8 mobile phone app. So the Issue is definitely with the Version 2.9 web player.
