BUG: Popular Tracks from artist have repeated entries in Plexamp
Hi all,
The Popular Tracks feature in Plexamp doesn’t return the same songs as in the default Plex player, and doesn’t match the list of Popular Tracks that’s shown prior to pressing “Play”.
Specifically, while in Plex it adheres to the list of Popular tracks being displayed, in Plexamp it includes all versions of the same song that may be in the library (live, etc), which makes for a terrible experience as we listen to duplicate songs in sequence.
Running 1.21.3.4046 server, and Plexamp 3.4.1.
Here are the examples:
Popular track list:
Playlist resulting from playing in Plexamp (it’s playing “Harmony Korine” right now, as was in the popular track list, and the next song is “Harmony Korine” the album version). See other duplicates such as “The Raven that Refused to Sing” and “Abandoner”.
Resulting playlist in Plex. Exactly as the Popular Tracks. This is the intended result.
Can this be looked into at some point? I imagine it’s a simple fix as it’s probably replicating the server API call that the normal Plex player uses? Right now, it’s what forces me to have to open the default Plex player to listen to some things.
Thanks all, and keep up the great work.
should be fixed in the next release.
Thank you @elan. Keep up the great work, and thank all the team for making Plex a great product.
Thanks. I confirm it’s fixed on 3.4.2.
