Those most recent update has broken the ability to remove the on deck feature on your Plex Library that we all hate. Before you could go to settings, server,library and turn the on deck to check zero weeks and this would disable On Deck showing. Now with the most recent update this does not work anymore. Anyone else having this issue
speak for yourself, that feature is good if you want to keep track on what are you watching, i guess you don’t keep track, you might like to scroll in the entire library to resume your tv show
you can go to your library>edit>advanced> and unpick include on dashboard
and will help when you post to say on OS you use, what player you use, might be from the player and not server ?
I have this issue. My On Deck was gone until this latest update. Even with the setting at 0, On Deck shows up.
- Win7, IE 11 to view my Plex server.
- Xbox One Plex app.
Setting to 0 was a nice way to remove it. I don’t want to go into all my libraries and uncheck them. People that like On Deck can use it. Those of us who don’t want it, now have no option to remove it from sight.
There is still a way, probably, but you don’t want to use it. (Set include in dashboard off) Since there remains a pretty easy way to take libraries out of “On Deck” I pretty much doubt there will be much sympathy for your plight.
**It really is a bug. ** I went into one of my libraries and unchecked Include in Dashboard. That Library still shows up in my On Deck.
EDIT: The Looney Tunes is the one still showing up. It shouldn’t.
“feature on your Plex Library that we all hate” 1st time I ever heard anyone hating on this feature.
