On Deck (edited)
Apologies, I had to edit my question. I meant On Deck not On Demand…Has anyone else not been able to remove the “On Deck” section from their home page of their Plex since the newest update?
be more specific, on what player ? because on what i use, i see no on Demand
Sorry, I asked the about the wrong section. I meant On Deck.
yep since the last update I cant get rid of it. I already have my On Deck set to consider 0 weeks for On Deck.
Appreciate the help flow but I already tried that…
Have you set “Include in dashboard” to no for that library?
@flow said:
Did you actually understand what sa2000 wrote? lol
While the general meaning of sa2000 statement is clear (that parameter is basically broken), the way he words his sentence is far from clear.
You change something to accomodate larger values for a parameter that is an “undocumented feature” (but still prominently placed in the settings UI), and in doing so you “inadvertently zap” that feature… let’s say they lost track of how that parameter works and have no idea how to fix that ;D
I’ve never seen a setting for “include in dashboard” and I’ve been through every setting option.
Not “every” setting.
In the main Plex screen in the web interface hover your mouse over the library involved and click on the three dots that appear.
In the resulting menu click on “edit.”
In the screen that results click on “Advanced.”
The resulting screen “Include in dashboard” is the first entry.
If you disable that option for the library, it also will stop any items from appearing in the “recently added” sections on the home page. So if you are just trying to get rid of the “on deck” section, it probably isn’t a real solution.
I found it… If I uncheck then I also disable the “recently added”, which would be no good.
