Bug with remote bandwidth limiting in local area networks
My assumption was that that was your server’s upload bandwidth is restriction being applied (however incorrectly). And that we’re trying to determine why that would be the case if the client IP is being reported as local.
The assumption I’ve been operating on (and trying to find evidence of in the logging) is that PMS is treating this as a remote connection even though it is reporting it as local in the dashboard. Presumably this would be because of some vestige of the traversal of multiple networks being detected by the logic which determines locality.
What’s that player’s quality setting? Original? Maximum? or 30 Mbps ?
(Remote and Home)
NOTE: The player won’t understand multiple networks. It’s either Same Subnet or Remote.
It’s the same client in both situations.
Router 1:
Is subnet 10.2.7.0/24 connected to Router 1?
Router 2
It looks like you need to adjust the static route in Router 2.
You do not need to route 10.2.0.0/16 back to Router 1.
All Router 2 needs is a default route pointing to 172.16.0.1, as that is the only path available.
I believe, based on earlier comments, that router 2 needs to have its default route configured such that it can reach its own Internet provider (or other upstream device?). It’s at another physical location, connected via a PtP wireless connection to the OP’s location. The static routes are intended to route specific traffic in this case. And, as shown in trace route output, traffic from 10.2.0.0 to 192.168.1.0 is routing directly (and correctly).
Thanks. Missed the “not my network” part.
Was looking for a way to simplify things.
Noble goal, and agreed.
[After looking at the client logs you shared]
I think your routing seems OK.
I notice that you’re using a custom certificate/hostname. Does the behavior change if you disable that? I don’t expect it to help, it’s just an easy thing to test.
I notice this difference -
In the 10.1 URLs file publicAddressMatches="1"
In the 10.2 URLs file publicAddressMatches="0"
So I wonder if either the client or server is using publicAddressMatches to determine if bandwidth limits are added during playback decision-making.
In both client logs, all registered server addresses are tested and all succeed. Good.
In both logs the 192-168-1-15.obscured.plex.direct server address is selected as soon as it responds. Good.
In both logs the [Transcoder] Video (decision) includes "location": "lan", although the maxVideoBitrate constraint is only applied to 10.2.x.x.
And as you showed originally, they both show as “Local” in the dashboad.
So I agree, kinda seems like a bug. I wouldn’t expect the bandwidth limit to be applied for a classified-as-local (lan) connection.
Or at least it’s confusing/surprising! I wonder what else publicAddressMatches might be used for.
@Baschtel14 I assume that the 30 Mbps is provided by the server, correct? If you change to 15 Mbps on the server, without changing any client settings, is that correct?
I agree here. Having looked at the client logs, the client on the 10.2.0.0 network is identifying server host at 192.168.1.15 and connecting to it. Why it is being reported as local in the server’s dashboard but having bandwidth restrictions applied is a mystery.
Yes, per an earlier comment, this is being applied by the server.
That question was to confirm that it tracks with the server setting, and to rule out it being a value that’s configured within the client. I’m 90% sure it’s getting that value from the server.
I’d like to know more about the MDE process. The server may give that value to the client, and the client may compare it with local settings and give it back to the server (as a profile augmentation) during the MDE exchange?
@Baschtel14 Would you be okay with my sharing of your logs with @Volts via private message? They can likely provide additional insight which could prove helpful. I’ve not found anything which suggests anything other than a potential fault in the way Plex Media Server is determining bandwidth restrictions in a multi-lan network environment but additional visibility may help. Let me know, or send the logs you sent to me to them directly. Thanks!
[Edited to add]
Per @Volts’ comment below, the logs have already been provided. Please disregard my comment. (You’re in good hands!)
He shared them with me too!
Derp. Carry on smartly!
yes that is correct.
I have removed the domain and certificat from the settings, but unfortunately it makes no difference.
Yes
It adapts to the remote limit.
Aug 29, 2023 19:34:31.568 [28340] INFO - [Web] [MDE] Augmented profile: {
  "directPlay": {
    "3gpp": {
      "video": {
        "maxBitrate": 15000
    "asf": {
      "video": {
        "maxBitrate": 15000
    "avi": {
      "video": {
        "maxBitrate": 15000
    "mkv": {
      "video": {
        "maxBitrate": 15000
    "mov": {
      "video": {
        "maxBitrate": 15000
    "mp4": {
      "video": {
        "maxBitrate": 15000
    "mpeg": {
      "video": {
        "maxBitrate": 15000
    "mpegts": {
      "video": {
        "maxBitrate": 15000
    "rm": {
      "video": {
        "maxBitrate": 15000
    "wtv": {
      "video": {
        "maxBitrate": 15000
  "directStream": {
    "video": {
      "maxBitrate": 15000
Aug 29, 2023 19:34:31.569 [28340] INFO - [Web] [MDE] Starting analysis of 4k (mkv, hevc, truehd, 153, main 10)
Aug 29, 2023 19:34:31.569 [28340] INFO - [Web] [MDE] Analyzing direct play
Aug 29, 2023 19:34:31.569 [28340] ERROR - [Web] [MDE] Invalid profile property; bitrate: 43924 > 15000
Aug 29, 2023 19:34:31.569 [28340] INFO - [Web] [MDE] Cannot direct play: validateProfileProperty:maxBitrate
Aug 29, 2023 19:34:31.569 [28340] INFO - [Web] [MDE] Analyzing video direct stream
Aug 29, 2023 19:34:31.569 [28340] INFO - [Web] [MDE] Analyzing audio direct stream
Aug 29, 2023 19:34:31.569 [28340] INFO - [Web] [MDE] Analyzing subtitles
Aug 29, 2023 19:34:31.569 [28340] INFO - [Web] [MDE] Subtitle codec: pgs
Aug 29, 2023 19:34:31.569 [28340] INFO - [Web] [MDE] Burn level: never
Aug 29, 2023 19:34:31.569 [28340] INFO - [Web] [MDE] Analyzing playability
Aug 29, 2023 19:34:31.570 [28340] INFO - [Web] [MDE] Finished analysis of: 4k (mkv, hevc, truehd, 153, main 10) {
  "canPlay": true,
  "canDirectPlay": false,
  "canDirectStreamVideo": false,
  "canDirectStreamAudio": true,
  "useSoftSubtitles": false,
  "bitrate": 15000,
  "videoResolution": 2560
Aug 29, 2023 19:34:31.570 [28340] INFO - [Web] [PDE] Player decision: {
  "playerType": "html",
  "protocol": "http",
Aug 29, 2023 19:34:31.570 [28340] INFO - [Web] [Transcoder] Video (start) options: {
  "hasMDE": 1,
  "path": "/library/metadata/11558",
  "mediaIndex": 0,
  "partIndex": 0,
  "protocol": "http",
  "fastSeek": 1,
  "directPlay": 0,
  "directStream": 1,
  "subtitleSize": 100,
  "audioBoost": 700,
  "location": "lan",
  "maxVideoBitrate": 15000,
  "addDebugOverlay": 0,
  "autoAdjustQuality": 0,
  "directStreamAudio": 1,
  "advancedSubtitles": "text",
  "mediaBufferSize": 157286,
  "X-Plex-Session-Identifier": "cx7g5qjzn3asgs679p0qaqqa",
  "session": "zpbjup64vxlga4kd0lzkk3un",
  "offset": 2139,
  "subtitles": "auto",
  "copyts": 1,
  "X-Plex-Chunked": 1,
  "X-Plex-Incomplete-Segments": 1
Aug 29, 2023 19:34:31.570 [28340] INFO - [Web] [Transcoder] Video (decision) options: {
  "hasMDE": 1,
  "mediaIndex": 0,
  "partIndex": 0,
  "protocol": "http",
  "fastSeek": 1,
  "directPlay": 0,
  "directStream": 1,
  "audioBoost": 700,
  "location": "lan",
  "offset": 2139,
  "copyts": 1,
@chuckpa any chance you could ask around internally if publicAddressMatches could be affecting bandwidth limits?
In his 10.1 client URLs file publicAddressMatches="1".
In his 10.2 client URLs file publicAddressMatches="0".
But everything else seems equal. Both player logs even show "location": "lan" during the MDE process.
But then just 10.2, with publicAddressMatches="0", applies the limits.
So I’m wondering if the client or server are using publicAddressMatches to decide if bandwidth limits should be applied.
@Volts
I went through the code (C++)
The logic I found:
  1. If there is an adapter on the host : Local
  2. If there is SSDP-discovered device, with gateway (has public IP that matches): local. (SSDP gets first layer devices only).
  3. Anything else in any combination chain or No Gateway: Not Local
This supports:
Host → Any subnet (adapter) rooted at the host.
Host → Any SSDP discovered device (router) with a gateway which matches Public IP
As example:
I have 192.168.0.x (my pfsense root),
Host is 192.168.0.20
Pfsense creates Virtual adapter 192.168.64.x/24
There is no routing / common path between the two networks.
PMS cannot see this adapter (in MyPlex)
192.168.64.x is REMOTE to my PMS server
(hairpin in the pfsense does not count as “local”. This is correct behavior)
I just tried it once.
I have set the default route to router 1 on router 2. So router 2 has the same public IP as router 1.
And then 4k direct play works on the network 10.2.1.0. No limits and no transcoding.
But the behavior is not correct in my opinion. If I add the network in Lan networks in the settings and the client can reach the server directly via the local network, then I want to have no restrictions, even if the network has a different public IP address.
Thanks!
That does make sense and I think matches what he’s describing.
But then, what’s the point of the LAN Networks setting?
I totally understand and agree with the security changes Plex made for ... allowed without auth.
But for bandwidth control, it seems like the LAN Networks setting should be the trump card?
(There were some other posts about “why is bandwidth control acting funky for my client on a local VPN? LAN Networks is being ignored.”. I’ll try to find them. I wonder if it’s related.)
@Volts
You can’t trump something just by saying “this is what I want” when:
  1. You can’t set a netmask which makes it legitimate
  2. It’s more than 1 hop away
  3. It doesn’t have have a gateway.
This whole problem is a network design problem.
In this case, PMS should be on a 10. network with a WIDE netmask to include it all.
( Example: 10.0.0.2/8 - 24 bit subnet with PMS on the first IP below the router)
where PMS is at the top of the heap, not stuck out in right field.
To fix this network is easy but it’s up to the users to manage their own networks.
  1. Make a big subnet
  2. Put PMS in the main subnet and give it a wide subnet mask
The whole network should appear “Subnet FLAT” to PMS.
Commercial networks are multi-hop
Home networks are 99.99% one or two subnets
This arrangement is far from normal or mainstream
