Server Version#: 1.32.7.7621
Player Version#: 10.3.0.4685
@marekszulik @ManuelPG @romancamelia @sixones
See list of bugs found on Plex Android TV:
I am having a recent issue where the same song will play twice at the same time. Playing locally streamed FLAC files.
Nvidia shield app 10.3.4685 (4ab0add)
W11 server 1.32.7.7621
The watchlist does not respect the “remember tab selected” option.
I can’t reproduce, it does go back to Recommended for me. Try toggling the setting on and off.
The pre-play screen has a “Mark as Watch” icon but it does not have a “Mark as Unwatched” icon
True, in progress items should have Mark As Unwatched in the context menu, it’s a bug.
If I select the “More” button I get a different list of options compared to when I long press on a video, and where they are similar, the order of the options are different
That’s expected as some of the options are present in the toolbar that has the More menu, so we won’t duplicate.
Navigating down on a playlist and then navigating up again causes a UI skip in the list
I can’t reproduce this, are you able to record the screen to show how it looks exactly? Thanks!
When I select “View My Profile” it just closes the Profile Page altogether and doesn’t actually go anywhere. This seems to happen for those who never enabled Discover since the new profile was introduced.
Yes, the profile is part of Discover. We’re working towards a solution that would let you browse your profile/friends’ profiles without the need to enable other Discover features.
I’m unable to start a watch together with any account on one particular Android TV box
Would you mind grabbing logs from that session? You can learn how to do that here: https://support.plex.tv/articles/201573117-android-android-tv-fire-tv-logs/
Other issues you’ve mentioned we’ll try to reproduce and I’ll pass some of the other feedback to the team, thanks for the effort.
I turned the option on and off again, and it looks to be working now.
Thanks for the note on the bug
I understand. Can the order of the items in the two lists be made the same? They seem to be placed in different locations in the two lists?
https://i.imgur.com/TG241FO.mp4 - This is a screen recording that shows after scrolling down a bit and then when scrolling up, the position of the highlighted row jumps up higher than expected
That would be good. I also noticed a bug where after exiting playback that was started from the watchlist, it jumps me back to my profile instead of back to the watchlist
My logs: logging.txt (4.3 MB)
Ah, ok - this is a scroll position issue, looks like correct items are being focused, but the list is scrolled unexpectedly.
That is very unexpected, can you grab a video of how it looks?
We don’t seem to have any good logging around that. I assume you have friends/users you share libraries with?
This came about when I turned on Discovery in the server and then after turning it off again. Maybe there was some lingering setting. But since turning it off, it hasn’t done it again. But that could also be because “VIew My Profile” no longer works for me with Discovery turned off. When I select “View My Profile” it jumps back to my home screen.
Yes, I have my account as the administrator and 4 plex accounts linked to Plex Home. I have the same setup on all my other TV boxes, but just on this one TV where it gives me the error.
I’ve made a few minor tweaks to the wording of my list of bugs in the Google Docs link.
The only way I was able to fix this was to completely factory reset the shield tv box to get rid of whatever residual configs were causing the problem
@marekszulik just checking if these bugs are still on the radar for resolution? I saw there was a recent Android TV update, so I went through my bug list to see if any have been resolved, and only really two that I could mark off as addressed.
