Bulk Edit Movie Labels?
Getting started setting up my libraries and I was wondering if there was a way to bulk edit the labels for a bunch of movies?
I’d like to take advantage of the labels to setup “kid friendly” movies and the ratings just aren’t cutting it since a lot of documentaries are NR and things like Jaws are only PG.
I’d really like to not have to click through 500+ movies one by one.
Any help would be appreciated. Thanks.
Just like in file explorer.
if you mant to mark several files in a row,
Shift+click on the first item, then scroll (slowly!) to the last item and Shift-click on that. all items inbetween are now selected as well.
For selecting non-contiguous items hold down the CTRL key and them click on the items.
Then click on the pencil icon, which appears as soon as you have selected several items at once
If you scroll while selecting, do it slowly!
Awesome! Thanks.
