Server Version#:1.23.3
Player Version#:1.33.0.2444
I’m wanting to create a library for Kids on the server, but don’t want to copy/duplicate files to have them show up in that library. It seems it “should” work…but how?
Can this be done, and how?
I tried creating a shortcut for a single file, then cut/pasted it into the Library folder and it didn’t work…so some guidance on how this can be accomplished would be great.
Maybe we need to put this somewhere in the Setup Guide to Plex?
The only PITA thing is you need to re-link both libraries when you do this, if the engine doesn’t already associate the file with a certain film…but a slick way to include a common file into two (or more) libraries!
I have a similar use case, handling up to three languages (English, German and French). Some movies on Arte France (Hotbird) are broadcasted with three languages e.g.
Solution:
folder X:/Movies EN-DE-FR → add to library movies EN, movies DE and movies FR
folder X:/Movies EN-DE → add to library movies EN and movies DE
folder X:/Movies EN-FR → add to library movies EN and movies FR
folder X:/Movies DE-FR → add to library movies DE and movies FR
folder X:/Movies EN → add to library movies EN only
folder X:/Movies DE → add to library movies DE only
folder X:/Movies FR → add to library movies FR only
The library “movies EN” collects media from
folder X:/Movies EN
The library “movies DE” collects media from
folder X:/Movies DE
The library “movies FR” collects media from
folder X:/Movies FR
This structure allows to save one file version only. This also works well, if I have two seperate recordings of the same movie (e.g. one version in German language and a different version in English).
More advanced tasks are to display meta data in the respective languages and to use poster pictures for different release countries of a movie, that look alike. Or to create a “best of” library, that combines files of the same movie in different languages. PLEX is only differentiating movie versions by resolution and Mbps, not language versions. There is no easy way to branch between language versions within a master library.
