Server Version#: 1.27.0.5897
Player Version#: 4.84.1
Has something broken in the latest update that now prevents editing playlists? This used to work fine. Thanks.
It’s working fine for me. Are you sure you’re not trying to edit a smart playlist?
It’s only a standard playlist, but it appears that there is a limit to the number of items. It’s a playlist of the MCU films and TV episodes, and the items at the top of the list still can be moved, but items in the middle just disappear when you move them and items at the end of the list don’t move at all. I had this working a few versions ago, but had to rebuild my server lately and this new playlist isn’t working.
I deleted that playlist and started another one from scratch. At 366 items, the problem came back. I can not drag items around. It does not seem to be related to the total number of items, as I spot checked the list as I built it, and it worked up to 241 items, but after it stopped again I deleted it back to 241 and it still does not allow dragging. I tried restarting the server, and the web player. No joy.
Please enable logging for the Plex Web client, recreate the problem, save the log to a text file, then upload that text file here for me to review.
Edit - Oh wait. So you can’t drag the items at all? The logs won’t help. Sounds like maybe something with your browser. Have you tried another one?
No, items do drag, but the items don’t stick to where they are dragged. Browser makes no difference.
Thanks!
verbose log:
“type”: “info”,
“host”: “app.plex.tv”,
“userAgent”: “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/15.4 Safari/605.1.15”,
“browser”: {
“platformVersion”: “10.15”,
“id”: “safari”,
“name”: “Safari”,
“version”: “15.4”,
“webkit”: true,
“platform”: “OSX”,
“platformID”: “osx”,
“platformModifierKey”: “command”
“version”: “4.84.1”,
“primaryServerUrl”: “https://192-168-7-252.b66e2a5f3ea54ea4a78d7f7fb38de42f.plex.direct:32400/”,
“primaryServerAuthToken”: true,
“username”: “pfern”,
“cloudUrl”: [
“scheme”: “https”,
“address”: “plex.tv”,
“uri”: “https://plex.tv”,
“testState”: “connected”,
“isBundled”: false,
“isFallback”: false,
“relay”: false,
“isUntested”: false,
“isPending”: false,
“isConnected”: true,
“isUnauthorized”: false,
“isUnavailable”: false,
“isFailed”: false,
“isAborted”: false,
“isLoopback”: false,
“isPrivate”: false,
“isHttps”: true,
“isSecure”: true,
“isPlexDirect”: false,
“currentTest”: null,
“sources”: [
“id”: “internal”
I need the entire log. That snippet tells me nothing.
