Can not add media after deleted
Server Version#:4.56.1
I somehow accidentally deleted episodes from a TV season. I tried to rescan library and it would not add the deleted files back. Then I somehow deleted the actual files from my synology as well.
I was able to recover all the episodes from my back up. I did the plex dance. I moved the files to a folder not monitored by plex, emptied trash and cleared bundles, etc… When I moved the files back and rescan the library all six season show but only the first episode of each season.
Any ideas on how to get Plex to see all 86 episodes again?
Thanks!!!
No I have no media.
app.plex.tv is unable to connect to “MediaServer” securely
I restarted and have access again. I did permissions adjustments you suggested and still only added episode 1 of each of the 6 seasons.
OK, it appears as if it is seeing all the episodes in a season as one. They show under duplicates. Any way to separate them?
I did not think split was an option for TV shows. They are properly named. I’ve never had a problem until I accidentally deleted the show. This is weird. It also did the same to another series I just added as well. After the update to DSM 7?
Here is a screen shot. I add all my movies into TV (formerly iTunes) and let them organize it. As I said, its never been a problem until today and last series i added after the DSM 7 update.
I’ve been doing it this way with no problems for years. Now all of a sudden it’s a problem. That doesn’t seem right… Now I have to go and rename thousands of episodes?
Thanks for the help, could do without the condescending language. Never had a problem until now.
