Cannot access PMS on an Old Samsung TV
I am running the PMS Version 1.20.4.3517
I have 2 Samsung TVs.
One is new, and Plex is working there.
I have one old Samsung TV that cannot access the server anymore.
So, I have 2 issues.
  1. Plex App does not generate the Code to connect to my Account/Server
  2. Plex App cannot connect the server directly.
    The message it shows is as follows:
Test failed, server is reachable but it returned: 'Access is denied'. Due to the security settings, this server is only accessable, when you are logged in your Plex account.
Current PMS settings:
Secure Connections: Prefered
Remote Access: Not Working
The Samsung TV is model UN46ES7000
Plex App is 2.013
Secure connections: Unchecked
Do you have any tip that I can try to make this work? Thanks in advance.
Go read this.
Alright, thanks for sharing this.
I will try to put this working. It may be tricky since I am not using Windows but Linux.
Lets see.
Yay!
Worked well.
Using the new version App with an USB
For the proxy.
I unpacked it with the msiextract and launched as note server.js
Followed the steps of the new app to setting the server ip, and that is it. Working.
