Cannot connect to PlexMediaServer-1.18.6.2368-97add474d-x86_64.qpkg on QNAP
Server Version#:1.18.6.2368-97add474d-x86_64
I just updated to PlexMediaServer-1.18.6.2368-97add474d-x86_64 on my QNAP TS-453a with Firmware 4.4.1.1146. The service starts but I cannot connect from any clients or the web interface on port 32400. The browser waits on this link: http://<my_ip_address>:8080/cgi-bin/
Anyone else having similar issues?
Here is the Plex Media Server.log file.
Feb 04, 2020 21:29:17.637 [0x7f9651ee9700] INFO - Plex Media Server v1.18.6.2368-97add474d - QNAP TS-453A x86_64 - build: linux-x86_64 qnap - GMT 03:00
Feb 04, 2020 21:29:17.637 [0x7f9651ee9700] INFO - Linux version: QTS 4.4.1.1146, language: en-US
Feb 04, 2020 21:29:17.637 [0x7f9651ee9700] INFO - Processor Intel® Celeron® CPU N3160 @ 1.60GHz
Feb 04, 2020 21:29:17.637 [0x7f9651ee9700] INFO - ./Plex Media Server
Feb 04, 2020 21:30:24.410 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.416 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.421 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.427 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.433 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.438 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.444 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.449 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.455 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.461 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.466 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.472 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.477 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.483 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.488 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.494 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.499 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.505 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:24.510 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:30.631 [0x7f965b77c740] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Feb 04, 2020 21:30:30.673 [0x7f965b77c740] INFO - OCSP: Successfully retrieved response from cache.
Feb 04, 2020 21:30:38.186 [0x7f963fc6f700] ERROR - Error issuing curl_easy_perform(handle): 7
Feb 04, 2020 21:30:38.186 [0x7f963fc6f700] WARN - HTTP error requesting GET https://94-55-166-55.2b4955add43c456894dd06189625cf0a.plex.direct:32400/identity (0, No error) (Failed to connect to 94-55-166-55.2b4955add43c456894dd06189625cf0a.plex.direct port 32400: Connection refused)
Feb 04, 2020 21:30:39.712 [0x7f963e4b0700] WARN - Sync: sync list 6576088 belonging to user 1 (Ery7) has died of old age, ignoring
Feb 04, 2020 21:30:39.715 [0x7f963e4b0700] INFO - Sync: downloaded 1 sync list(s) with 3 sync items(s): 0 new, 0 updated, 0 deleted
Feb 04, 2020 21:30:39.775 [0x7f962ee6b700] ERROR - LPE: unknown item 149972.
Feb 04, 2020 21:30:39.775 [0x7f962ee6b700] ERROR - Sync: failed to generate query for path library://24bf6d77-bd1d-4c85-8f8b-ef6cf13ed913/directory/%2Flibrary%2Fmetadata%2F149972%2Fchildren in sync item 40372128
Feb 04, 2020 21:30:39.775 [0x7f962ee6b700] ERROR - Sync: empty sync set, unable to update status for sync list 38214763, sync item 40372128
Feb 04, 2020 21:30:40.187 [0x7f965190d700] ERROR - Error issuing curl_easy_perform(handle): 7
Feb 04, 2020 21:30:40.187 [0x7f965190d700] WARN - HTTP error requesting GET https://94-55-166-55.2b4955add43c456894dd06189625cf0a.plex.direct:32400/identity (0, No error) (Failed to connect to 94-55-166-55.2b4955add43c456894dd06189625cf0a.plex.direct port 32400: Connection refused)
Feb 04, 2020 21:30:43.767 [0x7f963ff5d700] ERROR - Error issuing curl_easy_perform(handle): 7
Feb 04, 2020 21:30:43.767 [0x7f963ff5d700] WARN - HTTP error requesting GET https://94-55-166-55.2b4955add43c456894dd06189625cf0a.plex.direct:32400/identity (0, No error) (Failed to connect to 94-55-166-55.2b4955add43c456894dd06189625cf0a.plex.direct port 32400: Connection refused)
Feb 04, 2020 21:30:46.553 [0x7f9651bfb700] WARN - JobManager: Could not find job for handle 8129
Feb 04, 2020 21:30:47.447 [0x7f9651bfb700] WARN - JobManager: Could not find job for handle 8126
Feb 04, 2020 21:30:49.882 [0x7f9651bfb700] WARN - JobManager: Could not find job for handle 8286
Feb 04, 2020 21:30:51.982 [0x7f9651bfb700] WARN - JobManager: Could not find job for handle 8504
Feb 04, 2020 21:30:54.868 [0x7f9651bfb700] WARN - JobManager: Could not find job for handle 8769
Feb 04, 2020 21:30:55.825 [0x7f9651bfb700] WARN - JobManager: Could not find job for handle 8130
Feb 04, 2020 21:30:55.847 [0x7f9651bfb700] WARN - JobManager: Could not find job for handle 8631
Feb 04, 2020 21:30:58.414 [0x7f9651bfb700] WARN - JobManager: Could not find job for handle 8876
Feb 04, 2020 21:31:01.406 [0x7f9651bfb700] WARN - JobManager: Could not find job for handle 8979
Feb 04, 2020 21:31:14.245 [0x7f963e1c2700] INFO - Refreshing paths watched by LibraryUpdateManager
Feb 04, 2020 21:31:17.708 [0x7f962ffff700] ERROR - LPE: unknown item 149972.
Feb 04, 2020 21:31:17.708 [0x7f962ffff700] ERROR - Sync: failed to generate query for path library://24bf6d77-bd1d-4c85-8f8b-ef6cf13ed913/directory/%2Flibrary%2Fmetadata%2F149972%2Fchildren in sync item 40372128
Feb 04, 2020 21:31:17.708 [0x7f962ffff700] ERROR - Sync: empty sync set, unable to update status for sync list 38214763, sync item 40372128
After a rather long wait the following messages were added to the log and now I connected.
So case closed, I believe.
Feb 04, 2020 21:36:32.656 [0x7f95c6e6b700] WARN - QueryParser: Invalid field ‘libraryHubsOnly’ found, ignoring.
Feb 04, 2020 21:36:33.342 [0x7f95c7159700] WARN - SLOW QUERY: It took 850.000000 ms to retrieve 50 items.
Feb 04, 2020 21:36:36.268 [0x7f963dbe6700] INFO - AutoUpdate: no updates available
I am having similar problems on my QNAP TS-538 as well. I am in the process of rebooting and re-installing Plex Server.
I ssh’d and looked for other Plex processes. It turned out, there was another process still running despite the UI showing it was stopped. So I killed that process and restarted Plex, and after a little while I could connect to the web interface.
Hope this helps.
I’ve been having a similar problem for a few days. Using a TVS-471.
Updated to the latest version (V1.18.6.2368) on Tuesday which initiallh seemed to resolve but still recurring. Stopping and restarting the server app via QTS seems to resolve temporarily but appear to be an issue?
