Cannot install Plex on Samsung Smart TV
Hello
I have a Samsung TV model UE43MU6105. For some time,
When I try to install the Plex application, a message appears “Installation impossible. Try again later (118)”
Can anyone help me. Thank you
That error is coming from the Smart TV’s store. Unfortunately, Plex has no control of influence on this. You will need to contact Samsung to discuss why the Store isn’t installing the Plex app.
Hello
I am very sorry for this situation.
I contacted Samsung who turned a deaf ear to this problem. Which shouldn’t concern me.
In desperation I had to change the application for MEZZMO … !!!
Isn’t it possible to download the PLEX application for Samsung other than from the Samsung store, and install it on a stick via USB?
Thank you
To be clear, the Plex app is not actually installed on your TV even when using the store. The Smart TV apps are loaded into the TV’s memory over the internet just like a webpage. What you install is more like a link on where to load the app from.
Samsung does not offer a way to make this link manually or to load an app from a USB device.
