Cannot Remote Stream
Server Version#:1.42.2.10156f73b826c
I have been remote streaming for years with no issue. Starting 3 days ago all I get not avaliable outside your network. Nothing has changed on my end. Please help
Lots of things can change which are outside your control when it comes to remote access (or some accidental change you didn’t know might impact your remote access setup).
Did you already have a look at the related troubleshooting support article?
https://support.plex.tv/articles/200931138-troubleshooting-remote-access/
There’s also a guide with some more details on how to troubleshoot remote access issues:
Thanks ill check it out
Well still says unreachable from outside your network with a red x however I am able to remote stream now. Not sure why but I’ll take the win
There’s a chance the remote stream is listed as „indirect“ or „relayed“ on the “now playing” tile for that playback on the Plex server dashboard? If your client fails to establish a direct connection to your server, it might be using a Plex Relay server — that’s fine but those connections are limited to 1 Mbps (2 Mbps for Plex Pass members).
Exemplary screenshot from the "now playing" section
https://support.plex.tv/articles/200871837-status-and-dashboard/
Plex dash is showing direct play.
Direct Play refers to the video being streamed as-is vs. being transcoded. You’re looking for the part that says it‘s local, remote or indirect.
Yeah it does say indirect
