So I set it all up after seeing an article on how to run Plex on an ATV3 and every thing runs smooth except for one thing... I cannot view any of my material. It just sits there saying "Accessing Trailers" and after about 10 minutes it craps out and says "Trailers is unavailable. Try again later". I can view my library and all the rest of the jazz just not view actual movies. I know it isn't my laptop because I can stream movies to my iPad without a problem. It is frustrating to say the least... Below is a screenshot of what my terminal does when trying to stream a movie. Maybe a brighter mind could solve my problem?... Please?
ATV3
iOS 5.2.1
DNS server set on the ATV: 10.0.0.8
Device & OS with PlexConnect: Fujitsu LifeBook A series w/ Windows 8 Pro
Local IP address of the device that PlexConnect is installed on: 10.0.0.8
Device and OS with PMS: Fujitsu LifeBook A series w/ Windows 8 Pro
Local IP address of the device that the Plex media server: 10.0.0.8
Media is on internal drive
PlexConnect version: GitHub source, folder created on Thursday, 30 May 2013, 7:13:03 PM AEST
"Not Serving Client 127.0.0.1" means that someone on your host computer (the one running PlexConnect) is requesting data from itself. For whatever reason...
"/widget/rainmeter/weather" indicates the someone is actually some sort of weather widget. I have to ask myself, HOW it is meant to get information from itself :-)
-> The http header connected to this request does not contain an identifier of the sending host. This is the root cause for PlexConnect to fail.
For now, try to shut down the widgets and you should be fine - please report back. I will try to first check the http header or content before testing "host".
Thank you for your reply... I will try again with all my rainmeter widgets shut down as soon as the little one gets off of his Xbox and then I will report back :D
