Server Version#1.25.2.513-7000
I installed a new router and changed network lan ip addressing from 10.x.x.x to 192.x.x.x. I could get the rest of my network to work correctly, but I could no longer access PMS. When run from Synology package center, it tries to open (http://192.168.1.3:32400/web) and just spins. My app.plex.tv showed the NAS by name & just spins. After many tries using different solutions in the forum, I tried Chuck-PA’s solution of 1/18:
slow down… breathe.
- open app.plex.tv in the browser page.
- Immediately Sign out (upper right corner – click the Avatar)
- Now open http://192.168.1.240:32400/web (the IP address of your server
- It will want you to sign in. – sign in.
If you do not get it that way then continue below
- Sign into http://app.plex.tv again
- Settings - Authorized Devices - Server (dropdown)
- Remove (X) your Synology server.
- Don’t worry. We will bring it right back when PMS restarts.
- Look for other instances of your server there (Plex.tv might have a duplicate because of the networking change). If you see another, remove it too.
- Now sign out again.
- Restart PMS in Package Center.
- Open http://192.168.1.240:32400/web
- Sign in and “claim” if it asks you to do so.
Now, the NAS no longer shows as an authorized device, and I still can’t open the server from the package center. I really miss having PLEX, please help!
