Server Version#:1.32.5.7349
Windows 11 OS
Data and server are on the same computer.
My PMS has been running perfect for the last 2 weeks or so. Had 2-3 streams running last night both remote and local. I installed the newest update last night and ever since, it has been unusable. If I stop the sever and restart it will work for a short period (5ish min), but then completely freezes. I have uninstalled and reinstalled the server and that did fix the problem. I looked up how to roll back the updater but when I uninstalled, I removed everything so I think that data is gone. I have also tried other solutions like changing the DNS. What can I do next to troubleshoot?
It turned out to be a DNS issue just lome the previous post I had found. I just did not correct it in the correct place.
For anyone finding this looking for an answer, I first attempted to change the DNS server on my router, that did not fix the issue, which derailed me into thinki g my problem was different. I also came accross a post where someone has to change the DNS server on all their client devices, got me to thinking maybe one of my clients was disrupting the whole PMS. This also did not work, furthering my derailment. After multiple other rabbit trails that lead nowhere it finally dawned on me to change the DNS server on my Windows machine. I had made a half hearted attept earlier by going into the settings and searching “DNS” with no results and quickly abandoned that without following through. I finally looked up how to changed my Windows DNS server and was able to do so in the Network Adapter Settings. Changing is to Google’s Public DNS resolved my issue.
