I installed the Synology DS112J today and installed plex on it the first few minutes it worked. So i closed the screen etc later i wanted to change some things in plex and I cant connect to it with my synology.
Could anybody help me with this cause I have no idea what to do.
then i got to configure my router first in the synology but my router isnt listed i have the UPC Horizon box and thats also the router
The EZConfig in the Synology doesn't support all routers, nor is it the best way to configure your router. I suggest you work with the Synology forums for those issues.
