I can’t pause and then fast forward or rewind using plex dvr when watching live OTA. which means I have to watch all commercials. I see lots of issues with fast forward and rewind dating back over 4 years. Is there going to be a fix?
@Chris_Plex, If you want help, you gotta give us more info to work with!!! There are a lot of factors that affect this functionality. The biggest part is the Server hardware that you have as well as the settings that you’re using for your Tuner/DVR.
BlockquoteIf you want help, you gotta give us more info to work with!!! There are a lot of factors that affect this functionality. The biggest part is the Server hardware that you have as well as the settings that you’re using for your Tuner/DVR.
Here you go, this post almost 10 months old with this exact issue, and the devs haven’t responded in over 6 months.
Plenty of details in this one.
@rob132 Thanks for the link to the previous post and I can definitely see why you and @Chris_Plex would feel that the Plex team has been ignoring you. I, unfortunately, have no recommendation to fix this issue and it does seem to be a developer issue, I would say this though. Try the following link and at the bottom of the page where it asks " Did this help?" select No and enter your issues.
https://support.plex.tv/articles/225877347-live-tv-dvr/
You should get at least a reply this way. the forums are typically monitored by users. I can’t speak for the employee interactions here. I hope you get the help you seek.
